Is there enough room to install them or do they interfere with the edge of the gas tank?
Contact ESPO for some new springs if the rear is sagging. Fix it once, fix it right!
Thanks Bad Sport- that's what I thought. Would have to bend the lip which I would not want to do.
aftermarket-Monroe
A pair of load levelers on the back and worn out shocks on the front. I didn't care about comfort at the time, still don't. It was all about tuning the suspension for traction. load levelers helped with stock springsFishmen- I saw they were a factory add on part at one time, but the ones I'm talking about are aftermarket-Monroe
Anybody ever try the Load Leveling Shocks for the rear of a Duster. The ones with the coil springs. Is there enough room to install them or do they interfere with the edge of the gas tank?
They should fit fine. Load levelers were used on all our Mopars back in the day.
Those kept the 10" tires from rubbing on the fender lips of my 65 Barracuda when I loaded a couple fat chicks in the back. they made a terrible sound when they hyperextended, sounded like the floor was gonna come out.In my neck of the woods everyone used Gabriel Hijackers -air shocks.
