That last number looks like a 8
someone just milled or sanded off the Eddlebrock insigniaAttached are photos of a "B" aluminum View attachment 1715270840 View attachment 1715270841 View attachment 1715270842 intake that I am looking at.
The Chrysler part # is 2836148.
Does anyone know anything about it?
Thanks
Thanks!I don't know for sure, but it almost looks like the equivalent to an LD340 for small blocks.
Last # s/b an 8....That last number looks like a 8
.361, 383, 400
Wrong, wrong wrong. The DP4B and Ch4B intakes are all about bottom end. This intake is a DP4B made for B block engines. (350,361,383 and 400) They are not for the RB engines. (413,426 wedge, and 440) These intakes are VERY good street intakes with lots of bottom end and flow to 5500 or so.Thanks!
A member on FBBO said he thought it was a dead ringer for the Edelbrock CH4B. If it's the same intake then I figure Edelbrock manufactured it for Chrysler. I was looking at it [it's on ebay] for my 383, but I need low torque and the CH4B is a higher torque intake and is soft on the bottom end. The guy is asking $225 [obo] + $40 for shipping. It would be too salty for me anyway.
.Wrong, wrong wrong. The ch4b small block intakes are all about bottom end. This intake is a DP4B made for B block engines. (350,361,383 and 400) They are not for the RB engines. (413,426 wedge, and 440) These intakes are VERY good street intakes with lots of bottom end and flow to 5500 or so.
I corrected it. I got ahead of myself. I have sold so many LD4B's they are tatoo'd to my brain. LOL.
Do you mean the LD4B and the LD 340 small block intakes?
And don't forget the big block 350. It uses the same manifolds as the 361 383 and 400.
I don't know...I just pulled the info from a Hot Rod test article on the 'net. The test was made on a stout 440. I would, like you, think that by the intake being a low profile unit that the torque would be low end.Wrong, wrong wrong. The DP4B and Ch4B intakes are all about bottom end. This intake is a DP4B made for B block engines. (350,361,383 and 400) They are not for the RB engines. (413,426 wedge, and 440) These intakes are VERY good street intakes with lots of bottom end and flow to 5500 or so.
That was on a 440. Can't assume the same results on a B series, similar yes. Besides, with a big block, even with a stock 4 barrel, you're gonna have plenty of torque to move you. The differences are mostly gonna be felt on the time slipI don't know...I just pulled the info from a Hot Rod test article on the 'net. The test was made on a stout 440. I would, like you, think that by the intake being a low profile unit that the torque would be low end.
I made the ebay guy an offer on the intake.....I will keep the Domnator in reserve [in my mind]. I have an old '60's-'70's [?] Edelbrock Trantula TM6 on the motor now. When the rear gear gets changed from a 3.55 to a 4.11 I might be good to go with what I have...we'll see.That was on a 440. Can't assume the same results on a B series, similar yes. Besides, with a big block, even with a stock 4 barrel, you're gonna have plenty of torque to move you. The differences are mostly gonna be felt on the time slip
if you want a good street intake that allows room for growth, the Holley Street Dominator on a B series is pretty hard to beat. I had one on my 400, which later grew to 451 in my charger. Find one of them if you can would be my suggestion.
It's a dual plane intake. They are designed for low Rpm power and torque.I don't know...I just pulled the info from a Hot Rod test article on the 'net. The test was made on a stout 440. I would, like you, think that by the intake being a low profile unit that the torque would be low end.
DP4B.. The CH4B is for the RB'sTo me, the CH 4B is an alum version of the factory iron one. Or very similar. They are good for low and mid range torque. At High RPMS, the TM 6 would work better.
