MOPAROFFICIAL
Oogliboogli
Been running the same high flow Mr.gasket thermostat for 14 yrs. Never saw any plastic in it.
I can't see any plastic in the one I got. Just a bunch of deformed brass. Are you talking about the "Stewart" that sells water pumps? You know a distributor for their stuff? Thanks
Is there an update on this? What type of impeller does Your "high flow" water pump have,...is it composite? Did you cut apart the thermostat and see the remnants of the partI put a high flow water pump on the 340 in my Mirada. If you put a high flow component in one part of the system, I think you ought think about the rest of the system. After some research, I went with the Mr. Gasket Co. High Flow thermostat. 132 miles later, the car begins to overheat; fortunately on a few miles from home.
A couple of thoughts on this:
*I don't think plastic belongs in a component such as this.
*We originally were going to drive the Mirada to a cruise-in, Friday, about 150 miles away. But, a few minor things caused us to cancel the trip. Even though disappointed in not going, that decision kept us from a roadside breakdown due to the thermostat.View attachment 1714946762
.Here's the Mr Gasket stat I was gonna install tonight. How does something like this get packaged and not thrown in the trash where it belongs. Package was in perfect shape and this thing looks like a mess!!!! Glad I only gave $5 for it. Now I can properly dispose of it. View attachment 1715023065
Don't have a picture, but drill a 1/8" hole in the outer disc, or the part that doesn't move.Where do you drill this whole anyone ever picture
I had a girlfriend like that....My Mr Gasket already has a tiny hole from the factory.
