[Found!] Small block water pump pulley
$45 shipped
Got to state what year car ?
67-69 cast water pump
70- On aluminum water pump
Different animals.
I'm looking for a clean original single groove water pump pulley for a 340 engine assembly.
I’ve got one listed for 70 and later if that’s what you need. I also have s 69 and earlier. Pm me if interested.
Jake
Was used with a add on airtemp system ...utilized some how...maybe it's for big block.....really thought small
A/C had double grooves for 70 & up. That pulley looks older than 1970
Will check when I get home
To my knowledge, If you are talking about the water pump pulley, that is incorrect.
The water pump pulleys for a.c. or non a.c. cars are single groove only. The only difference between the 2 pulleys is the diameter, and height. Crank pulleys for a.c. cars are usually 3 grooves. 1 for the water pump,power steering. 2 for the a.c. and alternator.
29518-36 is the pulley you are asking for.
7 red flags will go up. 4 people will give you a different answer. 3 people will tell you to big block stuff worked for them. But when the smoke clears. Remember that number. Good luck on your mission. :)
I'm looking for a single groove water pump pulley for a 70 Dart 340 with a stock water pump - cast iron. Thank you for the numerous responses thus far. If anyone also has a single groove crankshaft pulley for a forged crank, I would be interested in that pulley as well.
Someone told me the part number he had on his 340 single groove water pump pulley was 2951836. Does that number appear to be correct?
70 340 should be aluminum water pump. The lower hose is on different sides.
I have that listed for sale. PM me if you actually want the right part or you can wait for this thread to keep going down.
Jake
