[Found!] Kickdown Rod for 4 bbl
KindredSpirit
Petaluma, CA
Fellow A body members: I am looking for a 4 bbl kickdown rod from the throttle cable bracket to the carb throttle stud. The rod I need has the threaded adjustment area on the carb end. My measurement from the bellcrank mounting hole to the carb stud is approximately 11". This is a '71 340 Swinger with 727 AT. Thanks.
You can just lengthen the 2 bbl rod about 1 1/2" - 2" and get it to work...
Read the second half of this article on how to set up a 4 bbl for info on how to lengthen the 2 bbl kick down rod to work with a 4 bbl...
How to set up a Holley 4 bbl for a Mopar
The pictures really help. Thank you. My existing rod is really in the wrong position even if it was longer. Maybe it's from a six. I am still looking for a rod with the angle toward the left valve cover as shown in these articles.
