[Found!] 14" small bolt pattern slots
Well ok, how bout a pair of 14" steel wheels? That would work too.
Shame you don't need rears, I have a pair of 14x9 aluminum slots. I have several steel 14 SBP.
I just got a pair of 14 x 7 for the rear. I would like a matching pair of 14 x 6 for the front, but I I cannot find a pair, the steelies will work.
Pretty sure I got an extra pair of 14 x 6 Small Bolt Pattern aluminum slots up in MN, got to let the nasty weather clear up there for 30 days, then I can check it out if you still need them by them. Price should be right, let me check them out. Shipping not too bad either on a pair.
Should look like the narrower pair here in this photo, you can put the final polish touch on them.
How soon do u need a pair? I would have to measure them to see what size they are. If u look at my 75 duster for sale thread u can see the front ones that are big bolt. Has a small bolt in the rear. Kim
I am in like zero hurry. Those look just like the ones I have. If the other pair you have is 14 x 6 I would be interested. Thanks.
Yes, those are 7" wheels. I need 6". I hate that you went to all that trouble.
These look the same as mine as well. As long as they are 14 x 6 I am interested.
OK, RustyRatRod I am making a note here and will contact you back when I get back to my MN storage and check them out Mid Spring. Thank you.
Thanks. As I said, I am in no hurry at all. I just put 4 new 13" tires on the car a few weeks ago, so I am good. I want the slots for upgrades in the future.
