Bring A Trailer
Couldn't break traction out of a U-turn? It's up to someone to fix that car, and its bent front bumper.
That poor thing is a turd. I wonder how many gallons of bondo was used to make it look smooth. How many corners were cut when making that shitbox?
Am I reading this right aluminum heads South Africa 72 demon for $2, 500. What is up with those flares leading from the back of the back door to the front of the back tires? Looks like some kind of thing I've seen on a Trans Am before. I'm inspired...
I’m not sure if I should laugh or cry.
$2500 starting bid and I’m not sure if that’s a flip- a lot of time was spent on that car.
318/904/8-1/4”
It’s a good learning piece for someone.
Lots to learn I guess.
At $2500, as long as it is not stolen.....
Buy it, race it, have fun with it.
Trashed it/wreck it..... screw it. Dump it in a trash can.
NEXT!
It’s an auction with two days to go.
Lots of questions on this one.
Bidding could be low.
Why does it have 75/76 rear bumper and quarters? Because the 72 bumper doesn't fit a 75/76. Hummmm What is the correct year ?
All the typical hackery under the hood.
Corrugated hose, one wire GM alternator, plug wire mayhem.:D
BUT, you could probably get your money back easily just out of the interior parts.
Well I don't know what numbers are with the car. But for sure the quarters at the bumper are are 75-76 as is the rear bumper. That rear bumper has to be used with that year 75 76 due to the impact shock absorber's that hold it on . A 73 and earlier will not fit that car if it has a shock style bumper mounts. But you can tel by the bumper indent in the quarter that it is a 75-76
But there are things that point to a 70-71. Cloth headliner, chrome rear window latches. 72 Dash Cluster. 70-72 Metal upper door interior. Looks like a Mutt. To many things are out of place
