I am using the exact same Lokar cable setup on mine with no problem. Been on about 10 yrs. (approx 20,000 miles) now and only had to adjust the slack twice. Like Tom mentioned 727's are notorious for shift rpm inconsistency, but yours is backwards from what I usually see. Generally the 2-3 shift rpm is low compared to the 1-2 shift. If I'm not mistaken the TF-2 kit comes with a spring to install in the part throttle KD valve, but it might totally eliminate part throttle kickdown. Get the ratio of the carb travel equalized with the trans lever travel and that should help. One last thing, I watched your video and agree with Rusty that it really don't sound that bad where it is. 318's like to rev so I'd leave it alone if it were mine
