Where to lift 65 dodge dart with this type of lift?
BeetleDart65
Lakeland Florida
Hello new to this forum and mopar. And I need help, I'm going to need to lift my 65 dodge dart . And the shop where I work at has this type of lift,
I was able to check some what I think are solid lifts puts on the car
Front:
Rear:
But I'm still not sure.
That's where i used to lift my car. Front frame rail cross member connection point and front of rear frame rail. Take her up slow .
Each lifting point only lifts 7-800 lbs.where it was mentioned. Lift a little and wait. If rails are rusted inside you will know right away. Always take the weight slow until you know it will carry it.
I prefer my drive on 10 time more than this style of lift.
Saw a beautiful mustang with buckled front rails from improper lifting.
If the fold up pads Can remain flat it will spread the load better too.
Thank you all for help and information. So I'll just put the legs flat and lift slowly on front connection point, and rear frame. Hope it goes well.
Yes any point where 2 or 3 rails intersect will be your strongest points
