dibbons
Trying to order the correct front wheel bearing grease cups. Thank you.
Wrong. I have an early 65 Barracuda that came with 9 inch brakes, 273 4bbl and a 4 speed with sway bar. I also have the build sheet for the car that shows 9 inch brakes.All 8 cylinder A body cars from 64 on until they went to front disc and big center hole in the 70's had 10 inch drums .Only 6 cylinder cars had 9's This doesn't mean you won't find 8 cylinder cars with 9's. People tend to use what ever they can when they need to get on the road and these cars all have history
I'm looking in the master parts catalog (genuine MOPAR not a reprint) for 1965 and everything in there for 9 inch brakes indicated 6 cyl. Go figure . I don't doubt what you are saying but it has to be real rare . The V8 cars have heavier torsion bars , a heavier center link ,heavier leaf springs , you know they built them different than the 6 cylinder cars why would they stick in 9 inch brakes? it makes no sense .Wrong. I have an early 65 Barracuda that came with 9 inch brakes, 273 4bbl and a 4 speed with sway bar. I also have the build sheet for the car that shows 9 inch brakes.
No not a Formula S but has everything besides the tach. Someone must have bought it to go fast and didnt care if he stopped. lolIs it a Formula S???
