Radiator Issue?
pacuda59
pacuda59
Pennsylvania
Have an issue that's poped up twice on me. Whenever I take a long ride of an hour or more I start to smell coolant. By the time I got home today the overflow hose was blown off and the radiator was dry. I flushed the system a few years ago with CLR and replaced the thermostat. Not sure what's causing this. Any guesses?
What engine, rad, modifications, did it ever work correctly, heater hoses connected, bypass hose connected?
When you say the rad was dry, you mean coolant below the core, or if you open the petcock on the rad nothing would come out.
Does your overflow have a vent? If not it would preasurize and could blow the overflow hose off.
how often since you flushed has the engine reached full operating temp?
Are you sure the thermostat is installed correctly?
I had to buy three thermostats before I found a good one, did you test it be installing it? Does it have a bleeder hole?
Flushing a radiator with CLR "a few years ago" doesn't mean it hasn't clogged itself back up. My experience with a CLR flush is it buys me about a year on the radiator.
And check this. I had a brand new thermostat that only opened about 1/8 inch. The temp would be fine for 20 minutes or so and then start climbing and never come back down. I put the old t-stat back in (it tested fine) and haven't had a problem since.
Do you have a temp gauge that is accurate? If the overflow hose is blown off, then that would seem to indicate the af is coming out the radiator overflow. Two causes for that, overheating or weak radiator cap. Buy a new cap. Cheap troubleshooting first shot. Lot of chinesium crap out today.
Pin hole in a hose..............
It's a /6 with the using the radiator it was born with I assume. I should have mentioned that last year around this time I bypassed the heater coil and looped the heater hose.
Yes, the coolant was below the core. Not sure if there would be anything draining if I opened the petcock.
The only vent I'm familiar with is the one on the neck which the overflow hose connects with.
I would say a couple dozen times.
I'm pretty sure, but I guess anything is possible. The picture is of the thermostat I removed.
What's the best product to flush with?
My temp gauge is broken. I'lll try a new cap and thermostat.
The only vent I'm familiar with is the one on the neck which the overflow hose connects with....
An overflow bottle needs to be open to the atmosphere. Tube on rad neck allows expanding rad fluid to go into overflow bottle. If overflow bottle does not have a vent it will presureize.
Was that thermostat from before or after the clr?
First thing you need is a new coolant temp gauge.
I never leave home without one.
Hope you did not cook an engine.
The temp gauge on my dash doesn't work along with fuel. That's part of the rest i've haven't gotten to yet. I hope not either.
I don't have an overflow bottle. Was that an option in 1969?
Before CLR.
My mistake. I thought you had added an overflow bottle.
Is overflow hose open?
IMHO if the brass t-stat was that bad I can't imagine what the rest of the cooling system looks like. I would pull rad, waterpump, timing cover and see what's going on in there.
Have rad professionally cleaned etc. Could be so much rust and gunk in the block.
The possibilities are endless. Cracked head,bad or wrong cap
Worn out water pump to name things not mentioned.
Last time i saw anything like that,well lets face it-i have never seen anything like that. The cooling system has to be pretty badly polluted to corrode a thermostat like that.
Bet water pump looks pretty bad too.
I don’t like flushing cooling systems in old cars. Freeze plugs & heater cores are the weakest links. Have had both of those happen.
Step 1. Get a temperature gauge. Fix existing or install an aftermarket.
Fill engine with proper ratio of coolant and go for a ride.
If engine heats up under load,likely its a pinhole in head gasket.
