Magiver
Dose anybody have knowledge of what it takes to install a rack in a 68 Dart?
like... none.. on a wide 68? You end up with a rather large turning radius, a wonky U-jointed steering shaft and possible suspension geometry issues. Sure its been done but it has its place on drag cars with limited steering requirement.Think hard before you answer..........what is the actual advantage?
So, what has to be done to put a rack in the front? I would think that the stock K member won't work. Iv'e heard that the left and right spindles can be swapped, moving the arms to the front.It saved me a ton of room on my 64 barracuda, I got B-Body race headers on it and not out the fender well, Down through the chassis. Bump steer was the hard part but I got it 0 bump steer through 3/4 of the travel, so then I just put adjusting bolts in the upper control arms were the bumpers used to be. Adjusting them so I got 0 toe through the whole travel.
My rack is also out front.
Gary how much did this set up cost you ? Looks solid , and does the stock steering column bolt up with minimal cobbling ?I put one in my 67 Valiant, as part of the Gerst K-member. I did it for the same reasons as you, I need the room for the new motor. You'll note I also got rid of the torsion bars for header clearance too.
View attachment 1715324780 View attachment 1715324787
This has been covered here before more than a few times. Just swapping the ball joints left to right to put the steering arms up front totally hammers the Ackerman. It's a lot harder than that to get a system that steers half decently.
If you need to have a rack, look at the coilover conversion systems out there- HemiDenny, RMS, Gerst, etc. At least with those systems someone has looked at the resulting geometry.
Of course, there are also more than a few guys that have done new engine swaps on these cars and kept the torsion bars, so, the argument that it has to be done for room isn't accurate. Yes, the torsion bar locations do complicate things, and the headers on some of those engine conversions are a pain. But it can and has been done. For that matter, the headers on an A-body are always a pain. And the coilover conversions come with their own issues. They stress parts of the original chassis in ways they simply weren't designed for. And there are track width and turning radius changes as well. Nothing that can't be overcome, but coil-over conversions DO have drawbacks. All suspension systems have pros and cons, that goes for coilovers just like it goes for torsion bars.
The new Borgeson power steering boxes are pretty close to the size of the original manual boxes. There are differences of course, but a new Borgeson box makes some of those swaps easier without doing a full K member and coilover conversion.
Hmmm...What are you? A 98 lb pipsqueak ???I can go with a manual box as long as I don't have to parallel park it.
It's not that hard if you understand it, all you have to do is go from the center of the rear axle with a straight line through the center of the ball joint to the center of the outer tie rod and the ackerman geometry is correct. that's what I did and it steers great. Like I said I fixed the bump steer to 0 through the travel also, It's not hard if you understand it.
Omg that’s 8000$ Canadian I need to win the lottery!The GTS kits start around 4 grand, depending on the options you want. I looked at several different kits, and preferred the Gerst. It's not cheap, but it's very well made, fits perfectly, and unlike some kits, the coil overs do not stress any part of the original car, as they are contained completely by the new K member. (See how the coil overs attach at the top)
I'm not using the stock steering column, so I can't give you an answer there.
You have any pics, further details on how you did this?Borgeson hydraulic power box, or use a mopar 16-1 manual box, and do an electric power steering conversion using a toyota yaris EPS motor mounted under the dash to a modified column. Problem solved.
