nm9stheham
OK, roger understood on the 'rust catchers' up there. Very true. Since the front was perhaps damaged and the tires were on there before repairs, then the tire wear patterns cannot be used to judge what is going on at this time. What we need from you is what alignment parameter was not achievable and in which direction + or -, and on which side. We cannot guess off of the tire wear as shown after repairs may have changed things.
Looking at your pix, the top pair of pix look to be driver's side, and based on the brake line position, the rear bolt is on the left and front bolt on the right. Please make sure I have that right. If so then the bolts are adjusted for almost as much negative camber as can be had. They are also set for nominally neutral caster, more + or - looks achievable. (They also look to be set in a way that may not make caster stay constant with suspension movement up and down.) A similar thing shows on the passenger side, although the camber is not set as far negative in its adjustment range.
Bottom line, there certainly looks to be some adjustment range left. But, with us not knowing where the adjustment is off, we can't say much more.
And none of us can say if the repairs fully fixed all the mounting points perfectly. That is not to say they are not... just that us on the other side of the internet can't know. BTW, it sure would be wise to put a thin coat of antiseize under the eccentric washers and on the bolts/nuts, including through the bushings. It's gonna keep the adjustability of the suspension in good shape for years to come.
