One set (16) small block hardened pushrods 3.340 length (from end of ball to inside bottom of cup). Should be standard for hydraulic cams, check your application. I also have a post for 21) 273 adjustable rockers with hold downs and spacers
$70 Houston, TX plus frt.
Thanks FABO
Thanks FABO
