mopower440
Question for the guys running fenderwell headers..what did you do about the 2 brake lines that go from the master cylinder to the proportioning valve? The fenderwell headers go right through the spot that these MC lines run.. Years ago when i put this car together (when i was a kid) I just bent the lines out of the way and did a horrible job. Today i tried to bend them a little more as they are too close to the header tube and cracked one of the lines coming out of the MC. SO, time to replace those 2 lines, but i will end up having to bend those as they will be the same shape as these were originally..Is anyone making prebent lines for fenderwell headers? Got to get this fixed asap..
