zigs
Does anyone know if a 68/69 Dart hood will fit a 70 duster. I think the GTS hood would look good on a Duster
Just found my answer NODoes anyone know if a 68/69 Dart hood will fit a 70 duster. I think the GTS hood would look good on a Duster
Right. Finding a donor GTS hood would be hard enough. It would be a lot of workYes It would look nice with the bulge GTS hood.
Unfortunately will not work. 67-69 Dart hoods are the same, 70-72 Dart, Demon hoods are the same. 70-72 Dart, Demon front fenders have the extensions on the front as to work with the 70-72 Hoods.
Have to find a way to graft the GTS Hood Bulges on to your 1970 Duster hood if you want to achieve those results. Although 70-72 Dart Demon hoods have ridges down the left and right sides that will interfere unless you move the GTS hood bulges inboard more. We are talking total custom work here.
As such in this photo of grafting the GTS hood Bulges onto a standard 67 Dart hood.
Example of what could be done to a standard 67 Dart Hood for those that want to customize things.
Thanks but I wouldn't want to spend $300 to hack up a good hood. I need something that's been damagedI have a factory donor hood for $300 if you interested. PM for pics.
