moparraceman
will a 1963 valient door fit on a 1963 dart ,both are 2 door hardtops ?
63 doors for Dodge and Plymouth A bodies are the same because of the latches. They are the same overall dimensions, as 64-66, but 64-66 doors have different latches.it should ,yes . I know the 65 Valiant doors are the same for Darts so I would think 63 is no different . You may even be able to use a 63 - 66 as long as it's the same body style
