For Sale is a Black floor shift steering column for Power Steering. Has the separate interlock safety column. I took it apart media blasted all pieces, them coated everything with Satin Black. Bearing were inspected and repacked. Turn signal switch and ignition switch were inspected. Ignition key cylinder is new as is the Large column to floor plate seal and the white floor plate to firewall gasket. Also the steering box slip joint was rebuilt. Fits 73-76 A-bodies. May also work for 71-72.
Also have a super nice black steering wheel for it. No cracks and has good color. Will sell both together or separately. $400.00 together or $275.00 for the column and $175.00 for the steering wheel. Plus shipping.
