New Hobart 140, helmet and gloves from the wife for Fathers Day! Also got an online rebate for a free welding cart from Hobart, wife is filling that out now
Yes, with or without gas and flux core. I haven't welded anything in over 30 years... some learning days ahead!That is awesome! Nice fathers day gift!! Can it be ran with or without gas? Can you use fluxcore wire in it? I have the cheapo harbor freight fluxcore welder. It works pretty good I'm still learning how to use it my welding skills are hit and miss! I can lay an absolutely beautiful bead one minute practicing then go to weld the piece I'm working on and be complete garbage. I think a lot of it is material types.
No.Hello RSie,
Nice gift !!!
Would you consider trading it for the Tie I received ?
Happy Mopar
Arron
Happy Fathers Day! There, now you got well wishes from me.I got nuttin'.....
Planning on getting gas, 023 tips and wire asap.convert it to gas when you get tired of messing with the flux core wire.. Northern tool has tank exchange. I think true value does also.
I had a similar issue. The drive roller needs to be for the proper wire,flux core uses a different roller. Also the groove needs to line up with the wire. On my welder if i tighten the retainer,it goes out of line. So i leave nut loose.That is awesome! Nice fathers day gift!! Can it be ran with or without gas? Can you use fluxcore wire in it? I have the cheapo harbor freight fluxcore welder. It works pretty good I'm still learning how to use it my welding skills are hit and miss! I can lay an absolutely beautiful bead one minute practicing then go to weld the piece I'm working on and be complete garbage. I think a lot of it is material types.
Sweet score! That's what I have. Love it.New Hobart 140, helmet and gloves from the wife for Fathers Day! Also got an online rebate for a free welding cart from Hobart, wife is filling that out now
Flux core AND gas, you say? Hmmmm. I'll have to try that. Good tip!Hey, great score! Going to be good to see you getting some sheet metal replaced in that ride. I recommend a combination of flux core and CO2/Argon blend gas for producing the best quality welds. Works really well when you have to trigger to prevent burn through and when interrupt/stitch welding large panel work.
