Having difficulty in finding the correct date coded wires for my '68 cuda, 383. Wire routing on an "A" body is different, the #7 wire is longer. Can you recommend someone?
Atlas have them correct date coded.Having difficulty in finding the correct date coded wires for my '68 cuda, 383. Wire routing on an "A" body is different, the #7 wire is longer. Can you recommend someone?
