[WANTED] Console brackets A body.....
MAPS
Montreal, Canada
Well I'm still looking for 4 Speed console brackets for a 69 A body barracuda.....
The car will be out soon so now I'm starting to get desperate lol I'm probably going to have to go with repro ones but I wouldn't mind getting a used set either.....it's not like they will be seen.
Thanks.
MAPS
Like you said, they are hidden. You could make some easy with some 1/8 × 2" flat steel.
I have a small break in my garage, but I'm gonna be out of commission for a while, or I would make you some.
RRA
I thank you kindly...but I can barely tie my laces..lol
If you can think of anything let me know.
The thing about the factory and repop brackets is they are shaped on the ends to fit the tunnel. The tunnel is not centered in the car and the brackets bias to the drivers side. Somewhere here on this site is documentation on where they go.
This is why I bought a template to be sure.
Thanks for the advice anyhow...
Maps
The brackets are the same as the Automatic cars except the auto shifter parts of the bracket. This may help you locate brackets as there are plenty of automatics out there.
If you do some digging there is a link to a youtube video of a guy measuring the attaching points. It was spot on for me.... I found it using the search engine here...
JW
