inner fender well weight
Well, ive seen some stock suspension drag cars cut them out, only to replace them with J bars from the cage to the front of the frame, with a connector to the top of the shock tower. Nice setup, I just wonder what the weigh savings are, if any.
inner deletes to J-bars are not for weight savings, more so to fit crazy exhaust or run coil overs and have a top coil mount. But since you asked....I just happen to have a set of inners sent to me and they weigh ~12 lbs a side. I bet the J-bar weighs more than 12 lbs.
Yup yup! Good stuff, thanks!
J bars to tie to a roll cage and stiffen it up for drag racing isnt for weight reduction, its to stiffen up the front end, and open it up for ease of maintenance on a drag car.
Forward struts used to triangulate the front frame in a Mopar
They say a picture is worth a 1000 words
The picture i was trying to paint was in the truck:wtf:.......I was so confused:D
:popcorn:
If the cage is moly than you’ll save 10-14 lbs. the undercoating is heavy too. But to be honest it’s done more for access. Least IMO.
