moparraceman
have a 1972 demon with 440 motor,alum radiator, lower hose drivers side ,upper hose pass side does any one have a part number for these 2 hoses ? parts stores are not very helpful thanks
The way I solved that was to bend a welding rod the way the hose needed to be then went to auto parts store and rummaged thru all of them hanging on wall that had the bends I needed then just adapted the long straight part to my desired length. The counter guys today bring zero value. They have to have a part number or they are lost.have a 1972 demon with 440 motor,alum radiator, lower hose drivers side ,upper hose pass side does any one have a part number for these 2 hoses ? parts stores are not very helpful thanks
HA! I thought I was the only crazy guy with a piece of wire, asking to go behind the counter to look at their hoses.The way I solved that was to bend a welding rod the way the hose needed to be then went to auto parts store and rummaged thru all of them hanging on wall that had the bends I needed then just adapted the long straight part to my desired length. The counter guys today bring zero value. They have to have a part number or they are lost.
I use a coat hanger and some times you just cut both ends to get your shape woks great. Been doing it for years.Gates 20609. Craig
Why not get a pair of hoses for a 69 roadrunner w/ a 440, u can always take them back after a check fit , u will probly be able to use them !Gates 20875 upper to RH on radiator. 20609 for lower to LH. Take a look at these cut to fit and they have the angles for big blocks. Size is for stock. Craig
I'm back there going through the hoses also. That's how you find the one that fits...HA! I thought I was the only crazy guy with a piece of wire, asking to go behind the counter to look at their hoses.
Not by a long shot. LOLOLHA! I thought I was the only crazy guy with a piece of wire, asking to go behind the counter to look at their hoses.
