Inspector71
Thanks. I bought the restoration kit and took apart the box and restored it. The door whose actuator rod is under the metal plate? Ha! Chrysler made no provision to remove it. I found a way but it was tricky. It was also the most rusty door on my California no rust car. I replaced all the foam and hit all rivet heads and problematic parts with POR15. I hate rust. I have one foam door piece left because my car is missing the driver's side air box door. You can have it
