Buford19
Cold air intake for gen 3 hemi swaps in a body mopar. Is the a aftermarket one that fits this application? If not any suggestions to building your own? Pictures and ideas would be appreciated.
Seen his thread before has some good idea for sure.Take a look at realwings build
That’s good to know, I want it to be drawing cold air from somewhere. Was thinking about running my intake down by the front spoiler. Just not sure if I will have enough air volume ,if the pipe is longer. If not I will make a box similar to yours.My fabricated box works great. The intake air temperature is usually about 100 deg F cooler compared to sucking underhood air. Much better for the engine. Ie less risk of detonation plus denser air= more HP
Jim
Thanks will check your thread out.Take a look at what i built...
its on this page under hemi swaps.... i think the title is air intake tube size.... check it out
