It will not be a performance gain over the factory roller cam, IMO.
that's being kind
Summit 6900 Tappet lift not specified, so I'm assuming .006 or .008, not .001
278/288/112
204/214 @.050
.421/.444 lift
Here's what that #6900 will feel like in your 360 @ elevation of 250 feet elevation (all work-ups will be at 250ft)
Static compression ratio of 8.0:1.
Ica of 68*, 250ft elevation
Effective stroke is 2.69 inches.
Your dynamic compression ratio is 6.26:1 .
Your dynamic cranking pressure is 116.83 PSI.
V/P (Volume to Pressure Index) is 95
VP of 95 is somewhere between slanty and smogger-teen, and will make a dog out of the 87 D100 up to about 3000/3500rpm, unless you install a a big TC and gears.
That cam needs
Static compression ratio of 10.0:1.
Your dynamic compression ratio is 7.76:1 .
Your dynamic cranking pressure is 155.82 PSI.
V/P (Volume to Pressure Index) is 126
to feel like a 5.2 Magnum
And
Static compression ratio of 10.5:1.
Your dynamic compression ratio is 8.14:1 .
Your dynamic cranking pressure is 165.96 PSI.
V/P (Volume to Pressure Index) is 135
To be peppy
and that doesn't even address where the intake valve actually closes.....
To be fair, once you get her wound up, say after 3600/4000, she'll start to wake up inside your 8/1 360.......... so with 3.21s and 235/75-15s, that would be
starting at about 36mph. Forget spinning the tires from take-off.
Now, if I got this right, the factory 5.9 cam is a 250/264/110 and in at 105(forget the 119 factory install) your Ica is 51*.
and I get;
Static compression ratio of 8:1.
in at 105 for Ica of 51*
Effective stroke is 3.08 inches.
Your dynamic compression ratio is 7.02:1 .
Your dynamic cranking pressure is 136.38 PSI.
V/P (Volume to Pressure Index) is 127
You see that 127VP? Thats a tic over a 5.2 Magnum (124VP), so now your 360 is taking off like a 318 Magnum..... up to about 3000/3200
The stock 119*install ( if I downloaded that right), will get you an Ica of 64* and you will get this pathetic deal
Effective stroke is 2.79 inches.
Your dynamic compression ratio is 6.46:1 .
Your dynamic cranking pressure is 121.93 PSI.
V/P (Volume to Pressure Index) is 103
Vp of 103 is IMO pathetic, I mean a Smogger-teen makes more than that; (~113), a slanty ~87
Bottom line is that cam is not a stab-it-in-and-go deal
Compare the
127VP of the stock cam advanced to in at 106, to the
VP of 95 with the #6900 with the Ica @68*... that is a direct loss of 25% low-rpm performance
If anyone has other specs for the stock 5.9cam,or specs for the 5.2cam, or knows the exact specs for the 6900, lemmee know and I will gladly edit.
