This one is on Mancini's website and they seem to contradict themselves. On one hand it states for drag racing use only, but the sentence below says it works on all stock ignition systems, no modification needed. I'm calling them.View attachment 1715363768
originally came with the Direct Connection electronic distributor kit.
i had 2 street cars i used them on, worked fine. these were nice for the conversion since they have the plug and play hook ups for the old style VR built inThis one is on Mancini's website and they seem to contradict themselves. On one hand it states for drag racing use only, but the sentence below says it works on all stock ignition systems, no modification needed. I'm calling them.
Great thread from 2018. Bookmarking for future reference.56 will work usually
58 is closer to the original terminal. The connector for a 56 is sometimes loose on a 58. Del has posted that sometimes one won't fit in the other.
Sources for Chrysler type wire terminals
