markfh
I had my steering box rebuilt and finally got to putting it back into my 68 Dart GTS. Problem is I can't get the column to go completely down the spline shaft of the steering box. What am I doing wrong?
Is the box bolted down tight? If so, try loosening the box then see if shaft goes all the way down. It just might be in a slight bind. Or you could loosen the firewall column mount a little to do the same thing I think.I had my steering box rebuilt and finally got to putting it back into my 68 Dart GTS. Problem is I can't get the column to go completely down the spline shaft of the steering box. What am I doing wrong?
Pic shows the little notch in the edge of the coupling that identifies where the master spline inside the bore is. The master spline in shaft should be right there on the top aligned with that notch.
