gunbunny
74 Duster /6 w/19" radiator.
less than 5K on rebuild 4 years ago.
Having an over heating issue at highway speeds.
If I'm not pushing the car, no issues.
So, with that info, I'm fairly certain that I have a water flow issue and not air flow.
Going into it with that thought process, I decide maybe I should flush system. Perhaps the clean up prior to the rebuild knocked something loose.
I took the cap off and while full I can see some crud is collecting badly in the radiator core. I have some stout cleaner and decided to add that and let it circulate. But when I open the drain ****, nothing comes out.
Now I'm concerned. I'm positive that I have a restriction, which explains the issue.
I drained some coolant and placed a quart of the flush and a 1/2 quart of white vinegar into the radiator.
Not convinced this is going to clear up the corrosion.
So, my question is, if I'm unable to find a new 19" radiator, will a 22" bolt into its place?
I'm not interested in a 3 core or anything fancy, just want to properly cool the engine.
