Buford19
Have a 67 fb barracuda, that’s in need of a new heater box. Which years ,if any of other A bodies mopars are compatible? Have a friend with lots of Duster and Dart parts, wounding if this is a option.
All you need to do is start a wanted thread and get what you need, what works.Have a 67 fb barracuda, that’s in need of a new heater box. Which years ,if any of other A bodies mopars are compatible? Have a friend with lots of Duster and Dart parts, wounding if this is a option.
plymouth and dodge the same?Any 67-72 A-Body heater box would be the same.
Just heater.is it heat only? or heat and A/C?
Ok thanks, this make the drive worth while to check out my friend parts.67-72 non ac boxes are interchangeable. 67-72 ac boxes are interchangeable. There are some minor differences in how the controls mount on the dash, but that can be improvised. In 1973 the systems changed a lot. That is when they went to the levers instead of buttons for the ac.
I put 71 dart ac box in my 69 cuda. It was originally a non ac car. It was a lot of work to swap from non ac to ac but worked out fine.
