One thing I will tell you also is if you have a lift in the garage that's a complete game changer when going BB. Just my opinion.....
JW,
will send you a PM on this, I don't want to hijack the thread but would like to pick your brain a bit.
As vs a stock small block?
Somewhere on the site he talks about the weight difference and changing of components such as brakes also. It's a pretty informative page for someone looking to do the swap.
JW
Nice job! Ive always been pretty stuck on headers, thanks for your info.95% street duty with no axe to grind on getting a certain number at your local track-small block. Currently going through the process of the RB swap now and it's not bad but it has it's own set of circumstances also. In all honesty if headers are a must have for you a RB is going to make you work at it harder.
JW
