The TF is not comparable to the W2. The W2 will out power it. Every time.
Aaaaaagreed
@JoeDragster
Take a good look at the unobstructed intake port. They can both, TF vs W2, flow the same numbers but it’s not the same intake charge. (Amount)
Imagine for A minute there are two super long roller coasters side by side. The coasters will go into a tunnel. (This represents the intake port.)
Coaster ride 1 (TF) is 3 people wide. (Width of the port)
Coaster ride 2 (W2) is 5 people wide. (Width of the port)
Both coasters travel at 300 feet per minute. (Rate of air travel speed of the head.)
Start counting people as they go by you at the same time for 230 seconds.
(230 represents intake duration at .050.)
How many more people entered the tunnel?
Since coaster 2 (W2) has a (wider coaster) wider unobstructed port to allow more people in, the party at the last stop (cylinder) is bigger, louder and more bad *** than where coaster 1 (TF) ends up at.
The party hall where there going (cylinder) are both the same size. The more people you can cram into the hall (cylinder) the bigger the party and the louder the noise.
(More air & fuel for a bigger bang equals more HP & TQ.)
