[SOLD] 340/360 SPOOL TYPE MOTOR MOUNTS
68 CUDA FORMULA S
Clarkston Michigan
Up for sale is a new set of 1973 and up 340/360 spool type motor mounts. These were mounted to my 71 340 motor but not installed. $60.00 shipped. I have been asked for better pictures and if these are after market or MOPAR, these are MOPAR you can see the pentastar in the last two pictures. Part numbers are hard to see but the first one looks like 3817169 under that it looks like 3817233-WH and under that looks like 387235-GR the next one is a little better to see 3642810 below that is 3642818-WH and below that is 3817122-GR both sides have the pentastar marking and the same numbers on both 3642802 BL and below that is 3642804 WH Hope these help.
Bob
