I need the line that runs from the driver side of the A/C Condenser to the A/C Compressor. I believe it runs from the front of the compressor, goes to the left side of the car around the battery and through the core support and connects to the condenser.
I also need the tube that connects to the evaporator and then the expansion valve connects to it.
Thanks in advance!
Thanks in advance!
