[FOR SALE] 68 barracuda 120 speedometer
Darren
ontario
1968 barracuda 120 mph speedo with trip.
50 $ Canadian dollar. Located in Sudbury Ontario Canada
Also have cluster housing and tachometer delete Insert.
That is the 67 only inst' housing, so some might question speedometer application. 68 and later have the clipped on cable design while 67 has threaded collector. Pic of backside of speedometer to verify?
Here is a a pic of the back of speedo (screw on). I can tell you My 68 Barracuda 383s built in march of 68 has screw on speedo. Maybe early 68's where still screw on?
There was a parts shortage due to a railroad strike. That's why the rally dash was placed in a few 68 Valiants. They used up whatever parts they had available. 68 model is supposed to have clip on speedometer cable, green dye circuit boards, dumb wheel radio, etc., etc...
So your speedometer wouldn't be correct for every 68. The one for sale here may not be either.
The clipped on cable is better engineering wise.
Speedo sold.
Housing and tachometer delete still available
