Which choke to use?
moparblood
n.y.
have a 78 van slant 6 came w/manual cable choke that never worked properly.
would like to use a good manual or electric choke but everything i seem to find is set up for a holley straight on. i have the carter 2bbl. which goes in a 90 degree way. any suggestions?
ordered the kit on monday, it just came today ! wed. i'll install tomorrow
i just did one of these setups, take a look at my thread...there is a level of nuance that isnt in the directions. I ended up having to make some linkage changes on the carb and running the Echoke with some extra rich preload to get it to function well. Works great after some tweaking
