[FOR SALE] 1990-1995 dodge dakota parts
moparmat2000
Grand Tetons
Parted out a 1992 dodge dakota extended cab. Interior was shot, so I dumpstered it. Rolling chassis is already gone to a new home, ditto for bed box, tailgate, and rear bumper, and transmission.
I still have a bunch of decent parts off it that need new homes. All the sheetmetal is rust free stuff. fl $150 on the complete floor. Has minor surface scale in one spot. $100 on the pair of rockers. Also have the gage cluster w tachometer, engine computer, wiper motor, steering column, decent condition hood, cowl panel, rust free RH fender, and rad support. Rust free inner fenders $100 pr, or $75 each if you only need one. Rust free doors that are straight with power windows and locks. $150 per door loaded, or $100 per door for the shell with the guts removed. I have a bunch of other stuff off it. Send me a PM with your needs.
Engine is listed in mechanical parts, but will list that here too. Does turn by hand pretty nicely, not locked up. Guy I bought it from wasnt too mechanically inclined, said oil pump stopped working. $150 for engine complete as it sits in the pix and I will put TB back on it. PS pump and bracket went with the frame. AC compressor is locked up. If you need parts off engine let me know in a PM.
Everything is located in west Texas. I accept PayPal.
I think that year Dakota has the large port exhaust manifolds?? Check the exhaust outlet and it should be 2 1/8" unless somebody changed them before you got the vehicle. If they are the 2 1/8" hole they are worth a little more than the regular manifolds.
Battery tray sandblasted. Will be applying a fluid resistant epoxy primer to it today. As you can see it is a nice solid part.
