dusterman440
Racing Enthusiast
So I'm in the process of digging into the front suspension of my 67' Valiant to do a 73'+ disc swap. With 67' I know the steering uses a different idler arm, so I wanted to double check before I mistakenly order rebuild parts for a wrong year.
I'll be ordering these items:
Can I order all 73' parts for this rebuild, without making other changes?
I'd really like to run the 73 LCA as I could completely rebuild them without tearing apart my car.
Thanks in advance!
Front inner and outer wheel bearings
Wheel bearing seals
Spindle nut kit
Rotors
Pads
Camber bolt kit
Calvert 90/10s (already purchased)
73'+ QA1 Upper control arms/balljoints (already purchased)
LCA Bushings
Greasable Pivot Pin
Lower balljoints
Wheel bearing seals
Spindle nut kit
Rotors
Pads
Camber bolt kit
LCA Bushings
Greasable Pivot Pin
Lower balljoints
(I'm pretty confident on it besides the 73'+ LCA's being a direct swap onto a 67'? I don't have a swaybar which I believe would be the only possible issue)
Thanks in advance!
