gregpurcell
Greg Purcell
Cleaning out the garage getting ready for the FMA show in Ocala this weekend. Here's the first table full of $5 each stuff. Scroll to the bottom! I keep adding more!
OK so far. we've got a body steering column holdup brackets, a length of defrost hose, rubber shift fork boot, two body tow hooks from a 66-70 B body, miscellaneous shifter boots & cover rings, slant 6 balancer & AC lower and water pump pulleys from late 60's early 70's A body, miscellaneous carb adaptors and spacers, 73 up spool type 318 motor mounts (no inserts), 73 up A body transmission mount with exhaust hanger, 73 up A body inner door handle cups, small block distributor holddowns, big and small block coil brackets, "V8" emblem with studs, insignia emblem (tape on), 66-67 Plymouth Fury AC plate, Certicard holder with all the mounting studs intact(embossed writing faded off) ALL $5 EACH plus the ride!
OH! The white bucket seats are from a 74 Dodge Colt but they can be mounted into anything. I can't ship but they will be at the FMA show this weekend for $30 PAIR!
