808-dartGT
It’s my first convertible 1964 dart GT, I put it on the lift while working on the brakes the other day. I noticed some body flex looking at the door gaps, I understand some flex is normal, but what is normal? Thank you
I think so , 4 point frame liftDid you lift it by the factory locations?
look in you factory service manual for the locations
It was 4 point frame lift, I understand engine and rear end hangs over posts so there’s some more weight hanging over than when it sits on its wheelsYes, they WILL flex when you lift them unless it's on a four post. Subframe connectors help to limit this, however.
That’s beautiful bottom!mine flexed a little bit. when on the rotisserie , but I do have to admit I didn't have floor pans or trunk pan in it when I did that, I did have it braced in the doors and windshield area. popped it down on wheels and axles . aligned the doors to the rear quarters and took measurements and then put it back on and turned it upside down. Then I welded in the floor pan. I now have good door gaps, much better than when I bought it.
Thank you!
I looked on their site, it does look like a lot of workIt's a 55 year old unibody put together with pinch welds... waddaya want??? I took Herb McCandless' advice a several years ago and started using US Car Tools' stiffening kits when I built cars. I'm on the third one now. For a street car, a set of factory style torque boxes and the frame connectors really make a big difference! The parts are downright cheap, but the welding work is extensive. The rugs and seats have to be out for the subframe connectors, and you want to be damned sure that the car is straight when to put them in because it would be hell to straighten afterwards.
