Press Fit vs. Full Floating Wrist Pins
OOOOPPPPSS!!! Normally I notice things like that.......better get my glasses checked.....
It's all pishta's and yr's fault, they opened back up and I fell into the hole:rolleyes::rolleyes:
Well .....it is Winter!!!!!!!!!!!!!!!!!! What else we gonna do?
so anyone asking today
still a good question
here's one answer
when producing 200 hp/ cyl we had trouble spitting double spriolocks out
I've never had a problem with pressed pins moving and scoring cylinders
I have had trouble with pins bending and cracking pistons and spitting double sprirolocks out
If you are going to be tearing down the motor floating pins in bronz bushing with pin oiling somehow
if not the pressed works just fine with proper piston oiling
some pistons are better than others
