doopdoop67
Hey guys quick question, I got a 360 mopar and I don’t have a flex plate for it. Where can I get one. Here a picture
Would the one from my 318 work?Do you want factory stock of aftermarket?
Look into Mancini racing.....flex plates from $16.00 to over $100.......take your pick
Mancini Racing Mopar Performance Parts - Yahoo Top Service Award Winner!
Do a junk yard crawl........any small block will have what you need.....keep the bolts, you will need them
Perfect thank you. I want an after market converter with the “mini stall” any recommendations?just remember the 360 is externally balanced....either you need a weighted flexplate OR a weighted converter ....one or the other....
so yes the 318 flexplate will work if you use a weighted converter....and make sure the flexplate and converter have the same diameter ...aka bolt circle....
We just installed a B&M 10239 ( externally balanced 360 with 904) on my sons 78 Magnum. I forget the part# for the same engine with the 727. Its heavy duty, overkill for the street, but not much out there if you want to run an unweighted converter. We found one on eBay, never used for about $85.Perfect thank you. I want an after market converter with the “mini stall” any recommendations?
What converter do you run?I have used stock flexplates for $5 plus the ride if you are using the factory weighted converter. If you want an aftermarket converter run the B&M scalloped 360 balanced flexplate.
B&M Flexplates 10236
