aussie duster
Hi guys ...need some direction on the correct rebuild kit for a bullet shaped manual steering box out of my 72 duster. Also where I can find instructions with an exploded view would be great....thanks
Firm Feel has rebuild kits. When I rebuilt mine I installed one of their 20:1 ratio worm gears.Hi guys ...need some direction on the correct rebuild kit for a bullet shaped manual steering box out of my 72 duster. Also where I can find instructions with an exploded view would be great....thanks
The FSM has info on rebuilding. Also do a search here on FABO, there is a post with photos and good detail. There are also posts on what lube to put back in. I use the Mobil 1 red synthetic grease.
I did the rebuild on the steering box a couple of months ago, but I also had the car down to a shell. Making good progress on getting it all back together, but it is still at least a month away from driving,, so no info on the 20:1 ratio.what's your opinion on the 20:1 ratio I know of a few and the owners like it better than the 24:1 and even the 16:1 .
