Help!! 3.59 Stroker assembly
LMAO, that’s why I asked you for the direct link.
No worries. It’s the same style (looking) piston right?
340 or 360 really doesn't matter. I've used 360 cranks in a 340 block. Mains have to be cut to 340 size. Deck heights and stock rod length is the same. Pistons have to be the correct compression height for the stroke and the bore size. I.E., A piston for a .060 over 360 will go into a .020 over 340 with a 3.58 crank.
Going 4.080 on any 360 or 340 should do a sonic check first.
