Princess Valiant
A.K.A. Rainy Day Auto
The thread....Backed into my garage.
Who's on 1st?The thread....
Don, it looks great! Soon........Backed into my garage.
Kind of reminds me of my remote trunk release on my Swinger. It is a very handy accessory! You are doing a kick azz job here!
So where is it now?
ah I misunderstood - pretty dumb of me lol! It’s Post 232 In the 47’s resto thread
Small update - my Mopar buddy, my wife and I Got the project out of the garage and turned around to back it in to give me more room on the passenger side to complete the same conversion as the driver’s side.
Good job as ususal Don! How was your D-pillars? Your work looks great as usual.I started working on the passenger side this afternoon. As I knew that the pillar between the right rear door and right rear quarter window had rust issues on the outer skin
and as I found out, so did the pillars inner skin after removing the inside plastic molding (which was also damaged -cracked and a big piece missing).
On the driver’s side I only removed what was necessary on that pillar to leave some support in that area. I decided to remove the whole passenger pillar and fabricate a new support later.
Correct Don! My buddy Johan bought the project and after the 1965 Dart 270 4 dr sedan he will turn into the project. He has gotten some sheet metal for as well as a nice restored 318. I think his going to make a 4 speed out of it.Hi Ulf - the D pillars are in great shape. I have a NOS set of wind deflectors that I will add to the D pillars. It seems the passenger side C pillars are the ones that has rust issues. My passenger inside of the A pillar was rotted but not nearly as bad as my C pillar.
I seem to recall on a wagon you had, one (or both) C pillar(s) were rotted like on this one. You cut and removed the C and D pillars to fabricate a Ute. Whatever happened to that project?
I'm pretty sure on that Don! You have great skills.If both C and D pillars were gone on this one, I would have turned it into a Ute. As it was, there was more rust than I expected for a CA car - 3 of the 4 floor pans, lower cowl, etc and once I got into it (both time and money-wise), it was too late to stop. I can start to see a little dot of light at the end of the tunnel, so I guess it’ll turn out OK!
Mega guts to cutI started working on the passenger side this afternoon. As I knew that the pillar between the right rear door and right rear quarter window had rust issues on the outer skin
Mega guts to cut
Do you have the non a/c firewall you took out, or did it tear up on the way out??Ah, not really after all the slicing and dicing I’ve done on this project - AC firewall for the non-AC firewall, complete cowl replacement, driver’s side conversion to the sedan delivery. Lots of planning then it’s a mettre of doing it. As one member said, “It’s just sheet metal!”
Don! What kind of brackets do you use on the inside to prevent the sheet metal to get noicy?Yesterday I fabricated the flanges that meet with the original rear side window flanges and got them welded in place. Today I started on that big side panel. I first cut a small test panel to confirm the height I needed between the flanges - just about 14 and 7/8 inches and as a pattern at the B pillar. The panel was pretty much the same height as the old side window until it started to curve back to the D pillar. On the lower flange it started to raise up about a foot or so from the D pillars flange. Then it was fit and trim at least 8-10 times to get a tight fit. What’s interesting at the area by the D pillar besides curving horizontally at the bottom, it also curves vertically ever so slightly going to the top flange - it all had to be hand formed! I will get it spot welded after I get another tank of welding gas!
I will turn out great. We just saw the first Crocodile Dundee when she arrived to Australia. I was surprised that I had never recognized it befo that they picked her up in a 1965 Valiant Ute! All of a sudden i watch the film in another perspective.
I couldn't help thinking about your car in delivery style compaing it with a Ute.
This is comin right along. You just keep going and going. Like the Energizer bunny. lol
I think the 2 door doors would have been better too! Wonder if they did any utes in South America? Like Argentina, Brasil or Venezuela.to answer your first question, when I added the B pillar on the driver’s side, I had to remove the roof cross brace since it was connected to the wagon’s original B pillar. I used part of the roof brace as one of the panel side braces. I did not need to cut the driver’s C pillar too much so I used it as the other brace. On the passenger side I will need to fabricate 2 side braces. I will use my sheet metal brake to bend as needed the braces.
I saw that Valiant Ute also in Crocodile Dundee. Funny thing, I went to Darwin Australia for a week each 2 times in 1981 and 1982 and never did saw any old Valiants or Utes!
It looks like when they constructed the Utes, they kept the wagon’s smaller front doors; IMHO they would have looked better with the 2 door sedan doors except they didn’t make 2 door sedans in Australia either. That’s why I went to the sedan B pillars and doors
