DesertRat
Leading edge boomer
Which fasteners holding the exhaust manifolds to a 67 273 head go into the water jacket? I'm removing my manifolds for beautification and don't need a floor covered in antifreeze.
Thanks I thought that was the case and my studs are in and sealed like frannies panties. Manifolds will be removed for significant improvement.outboard ends. Usually studded
In only three years so I'm not expecting any issues.part of my winter upgrade plans are to get the stock manifolds detailed and bead blasted. Then some high heat color TBD.Use 2 locked nuts to unscrew them but they will still probably break on you. Keep 'em in if you can. Serve as good header hangers.
