360 Bellhousing bolt size
74Scamp
North Dakota
Anyone have the length for the bellhousing bolts? I know they’re 3/8 but when I get my engine mated to the trans I don’t want to get in the predicament of not having the appropriate bolts to use. I don’t have any bolts either since the engine and trans were not mated prior so I need to get some. It’s a 360 and 904 trans. Thanks guys.
I might be using a washer if I can’t find a bolt with a washer head on it. RT specialties has a bolt set for $20 which isn’t bad but can anyone measure the bolts if they have some laying around?
