Aftermarket Wiper Linkage
Ben A...
Los Angeles
Hey there,
I need a full wiper linkage setup for a 73 Duster w/ 3-speed wipers.
Is there anything aftermarket available?
I only see the original linkages selling for 300 dollars on Ebay, but I'm hoping there's something aftermarket that costs less.
Thank you for any help.
Ben
Hey Ben
I'm guessing the wiper linkage for 2 or 3 speed is the same. I've owned both and other than the part that bolts to the motor its self- they look identical- windshield did not change size so the throw is the same.
As for aftermarket- nothing I know about. Wait for some one here who is parting out a car, they sell a lot cheaper than eBay.
Syleng1
Are you sure? I know in some years that bushings are different as well as crank arm directly off the motor. But the 3 arms arent they the same?
Pitman arms are typically different for the different motors but the 2 transmission arms would be the same.
Does anyone know if a 70 Dart 2-speed linkage would work with a 73 Duster 2-speed linkage?
The linkage bushing changed. If you used the complete pre 73 assembly, the pivots, linkage, and bushings... That could work
I've got a couple sets 68 72 A body...
May have a set from a 75.
Only functional difference I'm sure of with any of them is the motor cam.
If you know which cam part number you need...
