Let's keep it correct. No head work. Cam is .427 lift/204 @050 - less than a factory 360 4bbl cam. And you'd expect that with 2.94's? Stock converter?? Now recalculate please....A stock 360, aftermarket intake, 750 carb, headers, cam, mild head work...... should easily make 300hp.
In an optimized race car, that would be enough power to run 12.40’s @ 104.
If it was a 90% combo it could run 12.80’s at 101.
13.30 @3400lbs shows about 240hp.
So, if the motor made the 280-300hp it “should”, you have what’s likely about an 80-85% combo.
