quick release questions
A quick release what? Passenger injection seat. LOL
****, I was going to ask same thing..................Didn't someone JUST put up a rant about "supplying pertinent information?"
I "once knew" an engine with QUICK RELEASE CON RODS
You could look into the side of the engine and out the pan and SEE THE GROUND
JEGS 60724: GM Splined Quick Release Steering Hub Meets SFI 42.1 specs | JEGS
Got 3 of these in use on Mopars....duster and demon....
Used on drag car demon
Have no idea if the signal switch can be used or not....
